Can't use Dynatrace Plugin in Grafana OSS
Why we cannot use Dynatrace Plugin in Grafana OSS post installing that as earlier it was working fine , can you suggest any alternative over OSS
Dynatrace plugin is Enterprise (=paid) plugin
Hello @jangaraj We have installed the plugin by tweaking the values.yaml for Helm templates but during connection test its showing us the attached error , anyway we can utilize this plugin in Grafana OSS as if i am not wrong it was present earlier but now its entirely not. Kindly suggest whats the best possible available solution present in OSS.
Thank you.
See the error message. You don’t have license = you can’t use it. It is paid plugin = you need pay for a license, then you will have licensed Grafana Enterprise and you will be able to use that plugin.
That’s opinionated question. Literally, code your own Dynatrace plugin then. Or change your requirement, e.g. use Grafana Cloud instead of OSS, use/pay for Grafana Enterprise instead of OSS, …
