Can't install grafana raspberry pi 1B ARM/V6
Hi Community,
I’m a newby but try to install grafana on my old raspberry pi 1B lying around.
What I did:
  • install latest raspberry OS
  • install all updates with
    sudo apt-get update
    sudo apt-get upgrade
    also kernel
    sudo rpi-update
I have also installed Docker.io
Docker for node red was successfully installed, influxDB also.
After that, I wanted to create a grafana docker volume and install latest version:
docker volume create grafana
docker run -it -d
-p 3000:3000
–name=grafana
-v grafana:/var/lib/grafana
–name=grafana
–restart=always
grafana/grafana:latest
  • What happened?
    I get the following error message
docker: no matching manifest for linux/arm/v6 in the manifest list entries.
I als tryed grafana/grafana-oss but no success
My question: is raspberry 1B to old or do you have another path for a arm/V6 installation?
Thanks for help
René
I also try to reinstall everything, but same issue.
I have no ideas…
Are you new to docker? if so, just for beginners leave docker alone and try installing it directly on rpi
sudo apt-get install -y adduser libfontconfig1
wget https://dl.grafana.com/oss/release/grafana-rpi_9.4.7_armhf.deb
sudo dpkg -i grafana-rpi_9.4.7_armhf.deb
that was working! thanks for help!
