I have the following contents in my grafana.ini:
[auth.github]
allow_sign_up = true
allowed_organizations = […]
api_url = https://api.github.com/user
auth_url = https://github.com/login/oauth/authorize
auto_login = true
client_id = $__file{/etc/secrets/auth_github_oauth/client_id}
client_secret = $__file{/etc/secrets/auth_github_oauth/client_secret}
enabled = true
role_attributes_path = 'GrafanaAdmin'
scopes = user:email,read:org
team_ids = …
token_url = https://github.com/login/oauth/access_token
As you can see, I did use an JMESPath expression which does just evaulate to GrafanaAdmin. When logging into Grafana, I always only see myself assigned the Viewer role in my profile. Am I missing some configuration?
You are missimg at least:
allow_assign_grafana_admin=true
Shouldn’t it, according to the docs, in that case at least assign me “Admin” role? I also tried the Admin and Editor string, which both did nothing.
No, you requested GrafanaAdmin in your JMESpath. GrafanaAdmin != Admin - those are 2 different roles. GrafanaAdmin is “super admin” - more powerful admin role than Admin role, so there is also special config allow_assign_grafana_admin for that.
I said at least, so there can million other problems - use standard approach - debug logs.
For anyone else who encounters this I had to dig into the grafana code to get this working.
func (t *GithubTeam) GetShorthand() (string, error) {
if t.Organization.Login == "" || t.Slug == "" {
return "", errors.New("Error getting team shorthand")
return fmt.Sprintf("@%s/%s", t.Organization.Login, t.Slug), nil
It uses the slug from the github teams json. So if you have uppercase team names like I did, be sure to lower case them. The grafana documentation was unclear whether it used team name or the slug.
This did not work contains(groups[*], '@MyOrg/MyTeam') && 'GrafanaAdmin' || 'Viewer'. But contains(groups[*], '@MyOrg/myteam') && 'GrafanaAdmin' || 'Viewer' did.
