I am trying to understand which API is called during the gitlab Oauth authentication, to determine the gitlab groups and gitlab roles memberships.
My goal be able to configure role_attribute_path to apply a matching between Oauth gitlab group role membership and grafana role matching rule.
| gitlab | grafana |
| admin, owner | Admin |
| maintainer, dev | Editor |
| guest | Viewer |
I explored and tried around from the following docs without success :
- links to docs on grafana side :
- Configure generic OAuth authentication | Grafana documentation
- Configure GitLab OAuth2 Authentication | Grafana documentation
GF_AUTH_GITLAB_ROLE_ATTRIBUTE_PATH: (contains(info.access_level[*], '50') || contains(info.roles[*], 'admin' || is_admin) ) && 'Admin' || (contains(info.access_level[*], '40') || contains(info.roles[*], 'editor')) && 'Editor' || 'Viewer'
but so far no luck… ![]()
Thanks for any suggestion !
