Gitlab oauth role_attribute_path doesn't work
Idk is it a bug or i miss some important configuration piece. My Grafana installation isn’t assign roles to new users that i specified in “[auth.gitlab] role_attribute_path” config parameter. Event when i specify “[auth.gitlab] role_attribute_strict=true” and role “Invalid” in “[auth.gitlab] role_attribute_path” no errors appears in logs. Also in debug logs and in UI i can see that parameters from config were successfully merged and applied.
    11.1.0
    Assign roles to users using “[auth.gitlab] role_attribute_path” param
  • What happened?
    Although i see in logs user can successfully auth through Gitlab, no role assigned to user except one specified in “[users] auto_assign_org_role”.
    I expect param “[auth.gitlab] role_attribute_path” to work as it described in docs.
    (this config is not i really want to have in production. the intention of role ‘Invalid’ is to get some error in logs during debug)
[analytics]
check_for_updates = true
[auth]
disable_login_form = true
[auth.gitlab]
allow_assign_grafana_admin = true
api_url = https://GITLAB_URL/api/v4
auth_url = https://GITLAB_URL/oauth/authorize
auto_login = true
client_id = $__file{/etc/secrets/oauth-gitlab/client_id}
client_secret = $__file{/etc/secrets/oauth-gitlab/client_secret}
enabled = true
role_attribute_path = 'Invalid'
role_attribute_strict = true
skip_org_role_sync = false
token_url = https://GITLAB_URL/oauth/token
[grafana_net]
url = https://grafana.net
[log]
mode = console
[log.console]
level = debug
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[server]
domain = GRAFANA_URL
root_url = https://GRAFANA_URL
[users]
allow_sign_up = false
auto_assign_org_role = None
default_theme = system
    No errors. Looks like part of code that should use this variable isn’t work when user sign-in.
    Configure GitLab OAuth2 authentication | Grafana documentation
Ooookay. I found the problem after reading Grafana’s source code.
When i first tested Gitlab OAuth integration i made basic setup from UI, not from config file, to check it works fine. Then i start to add other configurations in config.ini.
The problem is that Grafana merges settings from its database (UI) and config.ini in a way, that all unspecified values in UI replaced by values from config.ini. That’s why in my setup i can successfully configure “org_mapping” (there no such field in UI), but value of “role_attribute_path” wasn’t overwritten from config.ini, as (i think) it was already in database (maybe some empty string).
Hopefully, i have a test setup and can recreate Grafana’s database from scratch. After that everything works as described in docs.
But it is rather confusing behavior :frowning:
