GitHub OAuth - How to map roles for users?
I have enabled GitHub OAuth and user’s are able to login via GitHub into Grafana. Evertyhing seems to work as expected that everyone are autoassigned to Viewer Role by default.
    Grafana v8.0.5, deployed via Helm Chart.
    Is it possible to achieve that i.e. GH Organization Admin/Owners will be attached to Admin role in Grafana, and rest of the users will have Editor role by default ? Is it somehow possible ?
  • What happened?
    Authorized user have only Viewer permissions.
    auth.github:
      enabled: true
      allow_sign_up: true
      scopes: user:email,read:org
      auth_url: https://github.com/login/oauth/authorize
      token_url: https://github.com/login/oauth/access_token
      api_url: https://api.github.com/user
      team_ids:
      allowed_organizations: mycompany
      client_id: xxx
      client_secret: xxx
Seems like only possible with the enterprise edition. See the documentation Team Sync | Grafana documentation
