What Grafana version and what operating system are you using? 10.2.3
What are you trying to achieve? Trying to assign Editor role while authorising GitHub OAUTH authentication
How are you trying to assign Editor role in Grafana for GitHub organisation member after setting up OAuth application and role_attribute_path = contains(groups[*], ‘nodbeku/teamgrafana’) ? ‘Admin’:‘Editor’
What happened?
Only Viewer role is assigned -
Change in the role from Viewer to Editor -
Assignment of role -
