Cannot read error message in "Edit Data Source"
I have a brand new install of grafana-4.6.3-1.x86_64.rpm on a RHEL7 server.
Graphite is up and running no issue on the same server. “rbox” is what it’s named. It’s listening on localhost port 8080 so I choose proxy.
When I try and add graphite as a data source, a red box comes up but there is no text in the box to tell me what the issue is. I set logging to debug and this is all the logs shows me.
t=2018-01-31T11:35:36-0800 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/datasources/proxy/1/render status=404 remote_addr=192.168.254.71 time_ms=58 size=36 referer=“http://rbox:3000/dashboard/db/graphite-carbon-metrics?orgId=1
Are you running Graphite version >= 1.0, otherwise please select the correct version when creating the datasource.
Marcus
