Cannot get the most basic query in Mysql to work in Grafana (solved)
Update: I was able to fix this issue by changing the column names in the database table from series-A, series-B to A and B respectively.
It might be a good idea to alert new users to the pickiness of the query builder regarding field names in the data. Apparently the hyphen in the name confuses it.
    MacOS Grafana v8.1.3
    display a simple graph from a table in MariaDb (mysql)
    1 Adding the data source OK
    2 Create a new dashboard OK
    3 add empty panel OK
    edit query NOT OK
  • What happened?
    When editing the query with the query editor various errors are displayed
    The graph to be displayed
    No
    The table I want to graph is a simple table with 4 fields:
| Field    | Type             | Null | Key | Default | Extra          |
| id        | int(11) unsigned  | NO   | PRI | NULL   | auto_increment |
| time     | datetime         | YES  |     | NULL   |                |
| series-A | float              | YES  |     | NULL   |                |
| series-B | float              | YES  |     | NULL   |                |
incidentally: this table was populated by exporting the random walk twice, and combining the two csv files in a text editor. The resulting file was imported into the MariaDb table.
When I add an empty panel to a new dashboard, the query builder has the following pre-selected:
Time column: time
Metric column: none
Select: Column: id
Where: Macro: $__timeFilter
Format as: Time series
The graph area shows a graph of a straight line rising from left to right (I assume it’s graphing the id value).
When I click on the plus icon next to “Column: id” and choose “Column” this adds a second column id. I Click on the second column and change it to “series-A”.
The result: the graph now displays: “Data does not have a time field” and an alert icon top-left.
When I edit the sql (click the button “edit sql”) to read:
SELECT
time AS “time”,
series-A,
series-B
FROM testdata
ORDER BY time
Nothing changes.
Hi @markchagers and welcome to the forum.
Glad you got unblocked on this. Is there a particular place in the docs that you found confusing?
Also, sharing your actual query will help users a lot. Many here are super good at querying the SQL datasources through Grafana
There is no particular place I found confusing, but I read nowhere that having field names with hyphens in your table is problematic.
As stated in the title, this query was super simple, and it failed with ‘series-A’ and ‘series-B’ as field names in the table. When I renamed those fields in the database to ‘A’ and ‘B’ respectively, the (accordingly modified) query worked as expected.
