Rename legend (currently 'unknown')
I’m new to Grafana, and I really love it!
How can I change the description in the legend? In every graph I make (based on Mysql data) it says ‘Unknown’ next to the colored line.
Can you please give me a hint? :wink:
Thanks!
Please refer to Using MySQL in Grafana documentation.
Must be a column named metric representing the time series name.
So if you have a mysql query you need to provide a column named metric, e.g.
SELECT
  $__timeGroup(time_date_time,'5m') as time_sec,
  min(value_double) as value,
  metric_name as metric
FROM test_data
WHERE $__timeFilter(time_date_time)
GROUP BY 1, metric_name
ORDER BY 1
Where the value of metric_name above will be used as metric column name and the value will be the legend/series name.
If you don’t have any column to use for the metric name you could do like this as well:
SELECT
  value_double as value,
  'my label value' as metric
FROM test_data
GROUP BY 1
ORDER BY 1
And the the label/series name will be rendered as my label in the graph.
Marcus
Works like a charm! Thank you very much! (I used the second option)
