9.3.2 -
I’m trying to produce a time series with multiple metrics. -
This is the SQL query:
SELECT
t.added AS "time",
t.value,
CONCAT(e.entity, '::', k.key) AS metric
FROM tsd t, entities e, keys k
WHERE
e.id = t.entity_id
AND k.id = t.key_id
AND k.key ~ 'weather.aqi.*.avg'
AND e.entity = '$hostname'
AND $__timeFilter(t.added)
ORDER BY 1
What happened?
I get 1 value, literally called “value” in the legend, instead of the expected (3 in this case) separate lines. -
I expect 3 lines, for the 3 different metric keys. -
No -
I’ve used almost the exact same query in many other panels (set up quite some time ago) that work just fine.
It’s also worth noting that the table view shows exactly what I expect, in terms of the data and metric names.
Did something change, in terms of what Grafana expects for the “time”, “value”, and “metric” columns for a time series? I’ve been looking through the documentation and can’t find anything definitive.
