v4.9.8 -
I want to overlap 2 kind of visualization each other, i.e TimeSeries on State Timelime chart. -
Using visualization panels I am trying to achieve it. - What happened?
Not able to achieve it - What did you expect to happen?
I am expecting grafana to show state timeline on time series chart with optimal color variations - Can you copy/paste the configuration(s) that you are having problems with?
no - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no - Did you follow any online instructions? If so, what is the URL?
couln’t find any
Hi @sourabhjain2,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![]()
Not sure but what you can do is try it out by clicking the “suggestions” as it will suggest some pre-configured panels with more defined settings for visuals and provide you a close match.
If that is not helpful then the only solution is to create a new visualisation plugin which can provide such results.
