I’m using grafana 8.3.3. And I’m trying to put a “time series” and a “candlestick” in one panel, Is it possible to do?
Thank you!
Hi @bd1736767412, welcome to the community!
Each visualization is its own panel. But you can select the special datasource - -dashboard- - in the query editor of a panel to share query results between multiple panels so they visualize the same data.
so,we could not use different visualizations in one panel? all the query in same panel must has same visualizations?
