Different Values into 2 Panels based on same report
Hello
I´m using Grafana to visualize data from a InfluxDB2 about my power consumption.
All running on a RaspberryPi 5 with actual versions.
I´ve dashboard with one panel showing the time series Graph with threshold colors for different threshold values.
Second panel only shows in a stat panel the last incomming value with same threshold behavior.
Now I recognize that sometimes both panels seem to be have different states.
For example stat panel show green low value for low consumption and the time series graph show yellow for higher consumption.
Now I´ve put last, min and max value in the legend of the time series panel and recongnize that last show different value then the stat panel.
Seem to be that the panels don´t refresh synchronized. Is there any possibility to prevent such behavior?
