How to overlap two " time series" panels in a dashboard?
Is it possible?
    Latest Version
    Make two time series panels overlap
    Just make it be transparent and moving it to achieve overlapping
  • What happened?
    Failed
    Two panel overlapping and they won’t move
    No
    No
No, it’s not possible to overlap panels.
But you can change content of a Time Series panel dynamically, using different queries specified as variable values.
See explanation here:
