Is it possible to change panel according to dropdown selector?
  • What happened?
  • yes I will
    So these are two panels I want to show only one according to dropdown change
You can use variables to parametrize your queries and change data in your panel:
variables
You can also provide queries via variables:
you can indeed change the visualization type, bar, time series, map etc in one panel if you use business chart plugin
I am using Infinity data source plugin Is it possible above approach in this type of data source
data is data, the plugin will work with any datasource. read the docu Business Charts | Volkov Labs
chrome-capture-2024-7-9 (1)
Sure
