Can I display my queried annotations behind the data?
    10.2.0 under windows 10 Pro
    Displaying queried annotations in the background for some data lines.
    Added an annotation query to my dashboard.
  • What happened?
    The annotations were display, but they were drawn in front of my data curves and are quite visually distracting, obscuring the data behind them.
    I was expecting them to be drawn behind my data.
    Nope. Ran fine, just didn’t quite do what I wanted and I can’t see anything in the UI that might let me change the behavior.
    Couldn’t find much, but the UI was a good lead.
@mikclrk I don’t believe you can adjust the z-level for Thresholds in the native Time Series panel.
Check out the Apache ECharts panel. It supports Annotations and can set z-level.
Hmmm. Thanks. That’s disappinting.
I really want to do it dashboard wise, as there are a couple of panels that show the annotations.
Thinking about it, I probably need to be able to set the z order for the individual annotation queries - so my red ‘major incident’ annotations are drawn over the orange ‘minor incident’ ones.
Sounds like it’s time to request an enhancement.
Mik
