Grafana 10.4.1 on Ubuntu 22.04 5.15.0-88-generic -
Show time regions in panel so we can highlight cirtical working hours. -
I refer to this doc : Annotate visualizations | Grafana documentation -
What happened?
Is it possible to display the highlighted time regions normally regardless of the current dashboard time range? Just like the sample in user guide :
"list": [ { "builtIn": 1, "datasource": { "type": "grafana", "uid": "-- Grafana --" }, "enable": true, "hide": true, "iconColor": "rgba(0, 211, 255, 1)", "name": "Annotations & Alerts", "type": "dashboard" }, { "datasource": { "type": "datasource", "uid": "grafana" }, "enable": true, "iconColor": "red", "name": "working hours", "target": { "application": { "filter": "" }, "fromAnnotations": true, "group": { "filter": "" }, "host": { "filter": "" }, "options": { "hideAcknowledged": false, "minSeverity": 0, "showHostname": false, "showOkEvents": false }, "queryType": "timeRegions", "timeRegion": { "from": "09:00", "timezone": "browser", "to": "15:30" }, "trigger": { "filter": "" } } } ] },``` -
No -
