Can I Create Dashboard of Dashboards
Hello All,
Is it possible to create dashboard of dashboards in Grafana?
For Ex -
I have 700 servers to be monitored. I want to display a simple overview of
i) how many servers are in GREEN status (monitoring parameters do not breach
any threshold values, ex- CPU< 70%),
ii) how many servers are in YELLOW status (monitoring parameters do not breach
any threshold values, ex- CPU Between 70% AND 80%),
iii) how many servers are in RED status (monitoring parameters do not breach
any threshold values, ex- CPU > 80%),
This way in a single view I can get the status of all the servers to be monitored. Is this possible in Grafana?
Thanks,
Rav
hi @ravindrabommakanti, there is no such facility in grafana to create dashboard of dashboards.
But to serve your requirement, you can create a simple dashboard where you can display summary of all servers with their status and filter on status.
And on click of one of the stats you can redirect user to another dashboard. So you can provide navigation in between two dashboards. But dashboard can only consts panels.
