Hi!
Grafana version: 9.4.7, Debian -
We are looking to create dashboards with tiles. Each of these tiles would display the name of the object and possibly a number (number of wifi terminals, servers…) It would be either green or red. Green to say ok, red to mean a problem. In case of problem, we could click on the tile which would take us to a second dashboard. This would show the details of the object (CPU, memory and storage of the server and the problem concerned for example)
Here is a dashboard that could look like what we would like: Dashboard CFTV | Grafana Labs
We’ve started to go through the documentation, but for now it’s hard to get an idea of how to create these tiles. -
Start by creating all second and detailed dashboard -
What happened?
Thanking you,
