I am new to Grafana, would like to know how to make a tile based dashboard.
I will use MS SQL as data source
I have attached an image for our reference, this is what i want to create, please let me know your thoughts.
Your “tiles” are named “panels” in Grafana, but of course that is perfectly possible. Panel layout and size on the dashboard is adjustable, just arrange them any way you please.
Thanks for the response.
I wanted to know how to design a single panel, I am trying with the Stat Panel, please let me know if any better option is there.
Also i want to show an image on the right corner.
Please see the attachement for your reference.
Hi All,
Even I’m looking for the same setup. Can some one please let me know how to achieve this.
Regards,
Satish
You could use Business Text plugin with custom css
