Better way to Organize Services On/Off Panel
    v9.4.7
    Trying to make a dashboard that shows the status of specific processes running on numerous systems. I would like to understand how to better organize and label this. I also noticed when I query Prometheus it says a system is running but in Grafana it does not, not sure why there is a difference.
    Currently using prometheus to query the systems and visualize the data in Grafana. Using stat panel in Grafana.
  • Issues you are seeing?
  • How to add text or label so I know the top row is server 1 and the next row is Server 2?
  • Is there a better way to organize this or do I have to create 1 stats panel for each process for each server?
  • Using stat panels I had to put the server with the most processes to monitor at the top of the page because new panels would always go “up” so Server 2 couldn’t have more panels than Server 1 else they will “move” up to the upper row
  • When I query this in Prometheus it returns “1” but running the same query in Grafana shows 0. Unsure why this disparity is happening.
Add ROW. Pin your panels to the row.
Cheers
Seagoon
