Hi , I am working on Grafana which is Connected to prometheus both of them running in an EKS cluster. -
I have an metric “UP” which is queried something like this :
up{app_kubernetes_io_instance=“$job”, pod=~“$node”}
This returns 1 or 0 based on if the cluster(application) is Up or Down respectively
I am trying to create a dashboard for my application and the up time is a major component of that, for which I am trying to create a “Status History” panel (suggest me if there is a better option) which would be in color green if the response of query is 1 which means cluster is up and cluster is down if the color is red.
- How are you trying to achieve it?
- I am creating a panel
- Choosing status history
- Query is up{app_kubernetes_io_instance=“$job”, pod=~“$node”}
- What happened?
The panel works fine and shows the information as I intend it to
But when I try to increase the time range for example 4 hours, 5 hours 1 day
It gives me an error like this
I want to have a fixed number of bars in the panel and the range change for each bar when the time range is increased
Can someone please help me achieve this?
