Bar chart x-axis - replacement of values from another column (visualisation)
Grafana v11.0.0-preview (ead392f6cb)
I am trying to display another information instead of the time information on the x-axis - populated in another column. The picture tells you exactly what I want.
I found some tips, but none of them work. I’m assuming someone must have dealt with this before. I’d be grateful for any help.
in Panel Option on the right side where you chosr bar chart viz there is an X config where you can choose that column ftom a drop down
I have gone through all the settings several times and there is no option to select quarter instead of the default time. That is the reason why I asked this question.
