my Grafana version : 12.0.2 -
I try to show value top of Bar chart in Time series Visualization but is not
i expect to show value top of
select time series and create Bar chart -
What happened?
Bar chart in Time series can’t show value on top -
i expect to show value top of Bar chart in Time series Visualization
i can show value top of Bar chart in Bar chart Visualization but is not my expected
