Azure Monitor: Query failed to execute because hinting request has failed
    Grafana v10.0.0 (81d85ce802)
    Windows 10
    Trying to visualize metrics of the SQL databases.
    Added Azure Monitor plugin and selected all the SQL databases from a resource group.
  • What happened?
    The query failed with the errorMessage:"Query failed to execute because hinting request has failed.
    Visualize the metric on the dashboard
    errorMessage:"Query failed to execute because hinting request has failed. Requested Metric:MicrosoftSqlShoeboxsouthcentralus|MicrosoftSql|cpu_percent. Output Dimensions: microsoft.resourceid. Dimension Filters: microsoft.resourceGroupName,microsoft.resourceId,microsoft.resourceType,microsoft.subscriptionId,ResourceId. RequestedSamplingType: Sum. Start time: 11/20/2023 6:28:03 PM End time: 12/20/2023 6:27:03 PM. Resolution: 00:30:00, Last Value Mode: False. Context:MetricsMP, CustomerId:Unknown. TraceID:{aaa-bbbb-bbb-bbb};AzSubId=999-999-999-99;AzResType=microsoft.sql/servers/databases;AzRegion=southcentralus;, IsUserQuery:1, ClientTimeout:00:01:40, ClientName:GatewayService-API->QueryServiceCoordinator, ElapsedTime(ms):18, Exception:System.ServiceModel.FaultException`1[Microsoft.Online.Hinting.Contracts.HintsRetrievalFault]: Number of filter values for dimension exceeds max allowed value.Dimension:microsoft.resourceid,Filter count:5102,Max allowed value:4000 (Fault Detail is equal to Microsoft.Online.Hinting.Contracts.HintsRetrievalFault)…
Is there any config to increase the max allowed value above 4000?
That looks like Azure limit, so try to ask your Azure support.
