Hi All,
I have an installation with Grafana 8.4.0 where I use the azure monitor plugin.
From the release notes of the plugin seems that the latest version is 0.3.1, but I have the version 0.3.0 installed.
If I install it manually it updates to 0.3.1 but nothing seems to work perfectly.
Is the latest embedded version 0.3.0 or 0.3.1?
Thanks!
How are you manually installing? With grafana-cli?
We just release 8.4.3, and if I look at the plugin catalog in the UI, it looks like Azure is pegged to 0.3.0…
