Hi Mates,
I recently installed latest Grafana version v6.3.5 and tried to use it with Azure Monitor, but get below error while adding new dashboard.
{“error”:{“code”:“MissingSubscription”,“message”:“The request did not have a subscription or a valid tenant level resource provider.”}}
And when I using the same configuration in Grafana version v5.1.3, it works well. So I think there’s compatible issue for the higher version Grafana with Azure Monitor, maybe it calls a different api?
It is very easy to reproduce. Can someone help on it? Thanks?
