Grafana added Azure data source error
There is an error when grafana adds Azure Monitor data source, showing Unexpected token ‘u’, “unexpected”… is not valid JSON, but I confirmed that the IDs are correct, and connecting to the api shows RESPONSE 401 Unauthorized. Is there any help here?
  • What happened?
I confirmed that the Azure subscription has permissions
This problem has troubled me for a long time. I hope someone has the same experience and solution, thank you!
Whats version of Grafana did you use and did you use correct steps of configure connection datasource to Azure account?
