Unable to add default subscription under azure monitor data source
I am using grafana version 6.7.2 hosted in docker container. While adding Azure monitor daat source, I am not getting option to add default subscription id, and it always stick on the choose option. Please find the attached screenshot,
I am able to add other fields , since default subscription id not added, my que
ries getting failed with unable to find the correct resource
do we have a solution for this issue?
same problem , same case grafana :7.5.10 azure , in app service
