Hi All,
Has anyone been able to setup Azure Monitor in Grafana to pull and display metric data? I have no issue connecting and finding log data (resources), but I cannot get any metric data to be discovered by the Grafana plugin. I can see and use the metric data in Azure, but not in Grafana. The account configured has read over the resources and will display log data fine.
Any help and suggestions would be appreciated.
Thanks.
Would you mind expanding on how this was done?
Firstly - is the end system a VM or on prem. I am working with Arc enabled on prem systems.
Secondly - are you using the legacy or newer Azure agent?
Thirdly - how are you data collection rules set?
Any help would be great.
I don’t have idea what are you asking
(because I asked “azure” team to provide credentials).
You have doc: Azure Monitor data source | Grafana documentation so follow it. You have test button in the datasource configuration, so use it. You can enable debug logs, … You have many options to get info about underlying a problem and you asked question which didn’t give any useful details “Has anyone been able to setup Azure Monitor”.
Data source has been enabled and working, as I’m getting logs fine. Just not metrics. I later expanded on my question and those points have not been answered. If your answer is to tell me to read material, its not been very helpful. Material has been read, and I dont know why I get some but not all of my data. Thanks.
I gave you recommendation - why you don’t follow it?
