Grafana 9.4.3 running on Windows 2016 -
Enable the AJAX plugin
(ryantxu-ajax-panel-0.0.6) -
Unzipped the source to F:\Program Files\o11y\grafana\data\plugins\ryantxu-ajax-panel-0.0.6 and check the config grafana file. -
What happened?
Nothing what I see: msg=“Skipping loading plugin due to problem with signature” pluginID=ryantxu-ajax-panel status=unsigned
logger=secrets -
An AJAX Vizualization Panel -
Directory where grafana will automatically scan and look for plugins
plugins = data/plugins
[plugins]
enable_alpha = false
app_tls_skip_verify_insecure = false
Enter a comma-separated list of plugin identifiers to identify plugins that are allowed to be loaded even if they lack a valid signature.
allow_loading_unsigned_plugins = true
Enable or disable installing plugins directly from within Grafana.
plugin_admin_enabled = true
plugin_admin_external_manage_enabled = false
plugin_catalog_url = Grafana Plugins - extend and customize your Grafana
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
logger=secrets
- Did you follow any online instructions? If so, what is the URL?
AJAX plugin for Grafana | Grafana Labs
