Signature has been modified regarding plugins
Hello All,
    Microsoft Windows Server 2019 Grafana 7.4.0
    Grafana Renderer plugin doesn’t work.
    With finding what is the reason for this error:
    msg=“Some plugins failed to load” logger=plugins errors="[plugin “grafana-image-renderer”'s signature has been modified]"
  • What happened?
    After Check Point EPS upgrades Grafana Renderer stopped working.
    This log I see every time.
    Configuration is okay.
    Yes:
    I didn’t find a solution for my issue.
I only find that the same server with Grafana is not working when Check Point AV EPS is installed.
I tried without EPS and the issue disappeared.
But it’s not the solution.
Please could you share with me exactly which files I should exclude for Check Point EPS AV?
The error on gui is:
We have encountered data source backend plugins that are unsigned. Grafana Labs cannot guarantee the integrity of unsigned plugins and recommends using signed plugins only.
The following plugins are disabled and not shown in the list below:
  • grafana-image-renderer
Modified signature
Note that unsigned front-end datasource and panel plugins are still usable, but this is subject to change in the upcoming releases of Grafana
Read more about plugin signing
I have the same error for Zabbix plugin:
Modified signature
Grafana Labs checks each plugin to verify that it has a valid digital signature. Plugin signature verification is part of our security measures to ensure plugins are safe and trustworthy.Grafana Labs can’t guarantee the integrity of this unsigned plugin. Ask the plugin author to request it to be signed.
Read more about plugins signing
Thank you in advance.
Best Regards.
