tonic8
1
Hello
i just setup a new grafana 7.2.0 instance to prepare a migration from my actual prod.
i installed through command line the Grafana image renderer, and when in the gui plugin webpage of the new instance i have a tag “unsigned” poping
is this normal baheviour for a Grafan Labs official plugin?
Hi @tonic8 - have you gone through the Troubleshooting Image rendering docs to confirm it’s not a missing dependency issue?
If your problem is similar to this user, that may help: https://github.com/grafana/grafana-image-renderer/issues/165#issuecomment-682484279
tonic8
3
Hello @anon80964540
not yet, my “issue” is not to render an image, but just after installing the plugin using command line,
It is detected by Grafana as “unsigned”. and i want to understand why the package is not signed, as it is an official package.
if it is detected unsigned for security reason i don’t want to use it until i understand the risk.
in the docs, they only talk bout issue when rendering image, not about the package itself.
but maybe it’s normal behaviour for everyone…?
Tonic8
