I’ve just installed Grafana 7.0.3 and can’t get the grafana-image-renderer plugin to work. I installed it as a plugin and got all the dependencies (OS: Debian Buster). My Grafana has an SSL certificate signed with an internal CA and LDAP authentication. Grafana runs on Port 443.
I’ve tried the following configs:
Not setting anything regarding the plugin (default values): Grafana tries to call
https://localhost:443/render, which fails withnet::ERR_CERT_COMMON_NAME_INVALID- which is correct. The certificate is for CN=mygrafanahost.local.lan. -
Setting:
[rendering]
server_url = https://mygrafanahost.local.lan/render
callback_url = https://mygrafanahost.local.lan/
doesn’t give an error in the log, but image rendering still fails, because https://mygrafanahost.local.lan/render/d-solo/000000476/mydashboard?orgId=2&... wants to redirect me to /login.
Any idea how to get image rendering to work with SSL, LDAP Auth and the plugin installed locally?
