I’ m moving to version 7.3.6 the lastest and i have this message:“unsigned plugins”?
Best regards
Best regards
is the message that unsigned plugins are allowed or did you dowload an unsiged plugin?
Hello @matigoal,
This is a message. You will not be blocked from using the plugins. However, if it is a backend plugin, it will not be automatically loaded.
Hope this helps!
yes no problem
