Add radar graph in grafana dashboaerd
I am using v9.3.2 and my operating system is 64-bit operating system, x64-based processor
How i make radar graph using CSV data.
I am addded radar graph plugin in my dashboard.
I have no idea how to add data , and what type of data format i pass in query to create radar graph.
Thank you
Welcome @anand17
Could you please provide your csv data?
like following
name, max
Sales, 6500
Hello @yosiasz ,
Im sharing you the screenshort where im using csv content and that radar is not working. So im confused Is I missed something. If you have any csv content that I can use it directly so I get some reference from it how we have to provide input to show the radar.
I would use the more robust apache echart plugin instead of that radar plugin
in the editor section use the following js code.
let values;
data.series.map((s) => {
  values = s.fields.find((f) => f.name === 'value').values.buffer;
return {
  title: {
    text: 'Anand Kumar'
  legend: {
    data: ['Anand Custom Values', 'Actual Spending']
  radar: {
    // shape: 'circle',
    indicator: [
      { name: 'a', max: 30 },
      { name: 'b', max: 150 },
      { name: 'c', max: 45 },
      { name: 'd', max: 123 },
      { name: 'e', max: 100 }
  series: [
      name: 'Budget vs spending',
      type: 'radar',
      data: [
          value: values,
          name: 'Anand Custom Values'
but if you want to use that plugin it requires a time field
metric,value,time
a,10,2023-07-13 10:00:00
Hello @yosiasz
Thankyou for your solution.
Here my screenshot using radar graph plugin.
Hi @yosiasz
how i change the echart background and line color as you provide in your solution above.
Check it out here
