Not able to achieve a line graph
Hey friends!
Grafana v11.1.0
I have been trying to implement a line graph through various methods (Tried with trend chart - got error saying values must be in ascending order, tried with other ways just to see no visual)
Attaching the screenshot of my graph as a bar chart:
This is the table view of my data that I am trying to represent as a line:
I am now trying to use a new plugin called business charts and using a line graph in that. When I put in my fields to visualize, I am seeing a blank graph not sure why:
It’s been several hours I have been trying to figure why this is not working as expected, can anyone please point me in the right direction on how do I achieve this? I would really appreciate the help! Thanks in advance :slight_smile:
It does not seem the data you posted came through clearly
what is your datasource? mysql? or api?
I am using Elasticsearch as the base. This is my base table:
I am trying to achieve this visual:
Thanks for the quick response!
using business chart configure things as follows
then add the following code
return {
  xAxis: {
    type: 'category',
    data: ['Perfecto', 'Dulce', 'Gracias', 'Linda', 'Bailar', 'Gosar', 'Dormir']
  yAxis: {
    type: 'value'
  series: [
      data: [150, 230, 224, 218, 135, 147, 260],
      type: 'line'
in the following are
Now this is of course just to get you started. You can get your data to populate using javascript.
Follow this docu for further coaching
Hi @yosiasz
Really appreciate your quick responses.
I am attempting to use Business Charts as directed and using my own data from Elasticsearch as shown below:
I am then performing a bunch of transformations on the data as shown (essentially to get the fail %):
The final output looks like this in a table view:
I am using Business Charts as you advised and am preparing the line graph as follows:
But eventually, I am seeing a blank graph and not able to see any kind of visualization on my end.
This is the expected graph that I am wanting to see through these transformations and using business charts:
Can you please advise on what am I doing wrong here, or if there are any alternative approaches to what I am wanting my final visualization to look like in Grafana.
Thank you for your continued support!
check your data point in your browser console by doing console.log(context.editor.dataset)
that should start giving you hints as to what you need to do.
Not sure, but getting this error:
so this is probably a good time to read the docu on business chart on
