Grafana OSS 10 -
i am attempting to take a .svg, overlay a dot on it with x,y coordinates and have a function change those x,y coordinates every second. the goal is to see the dot move around on the .svg map
basiacally:
i am trying to take this Apache Echart Example:
and display it on Grafana.
i have installed the Business Charts plugin from volkovlabs, copied the full code from the example and pasted it into the java script section of the plugin. Settings set to svg, map set to none. -
What happened?
There is no visualization output. -
i expect a replica of the example, an icon moving around on a map which is along x y coordinates. -
there are no errors on the log -
i followed these instructions: https://www.youtube.com/watch?v=DxqCrBEmrQw
