11.0.8 -
I want to use 2 different unit formats within a table. -
see screenshots below -
What happened?
every field is displayed in kWh
Autarkie and Eigenverbrauch should be in % -
Can you share the entire table here? What are the rows labeled?
Override is per column, not per row.
If you want to show different units per row, then generate cell values as a string with units, e. g. 98 %, not just 98. Of course then other table functionalities will be affected, which expect numeric values can be affected, e. g. sort, thresholds, ..
as @jangaraj said stringify it, you would of course need to use some sort of CASE statement to decide which unit it should be
can you share a sample query how to generate cell values as a string?
I am using InfluxDB 1.11
IMHO that’s not possible. But I guess you can add additional query, where you will prepare unit data and then join (keyword “transformation”) that with metrics data and concatenate correct result - that’s “cell values as a string with units” in your case. But this approach will generate other subtasks, which you need to solve - don’t expect single task, but a few tasks (each of them can be sorted already as dedicated topic in documentation/forum) until you reach your goal.
