How to format a column of a table to the $$$$ format?
Hello Grafana community,
I have the following table below, which comes from a Rest API data source (Infinity Plugin).
Some columns in this table need to be in the format “$ x.xxx.xxx,xxx”. Is it possible to format them without changing the API?
Hi @mattospe
Have you tried an override for the field you’d like to change, like this?
You can “stack” the overrides, i.e. one for the number of decimals to display, one for the units, etc.
