Custom format for inspect data
Hi there,
i have been looking for a way to format the decimals that i want to export. In the inspect panel there is the option enabling Formatted data. When enabled it displays a Integer version and when disabled the raw data. I would like to always have a fixed amount of decimals, if the end value is zero to be displayed. Is there a way?
Best regards,
amermelao
I don’t think there is currently a way how to apply field overrides (to increase/decrease the number of decimals) based on the value from that field. There are currently following options to override. But I think this could be nice feature request. So if this would be useful for you, it would be awesome if you created a feature request in our github and shared your usecase.
hi,
thanks for the answer.
