Dear Grafana community,
I just start using grafana and I am going to add different units to columns of a datatable.
but the unit apply to all columns except the time.
Is it possible in grafana 8?
The last column need to be in percent.
Hi @ziaeemehr
This is totally possible in Grafana 8. You need to set two sepearate field overrides and then set the unit for each field. This way you can have granular control over every column in the table:
