Like topic Zabbix-maintenance-window-show - General - Grafana Labs Community Forums without Answer,
I would like create a Dashboard which print Hosts In maintenance
And have a full maintenance Dashboard.
Could somebody Help me ?
Regards.
Regards.
Hello Fredericarnould85
You can use the direct connection datasource to the zabbix database and run an sql query to list the hosts that are in the table.
With the Zabbix Plugin, it is currently not possible to list only hosts.
You’ll need to use a direct connection to SQL database for this. Try to see if “automatic translated subtitles” helps you follow this exactly feature on this videos:
