We are using Grafana as a Zabbix dashboard. I have a few variables set up that are working and I want to simply create a panel that lists all hosts and one that lists a total of those hosts. For example, my $group variable is working and shows me my Zabbix groups and my $host variable is working and shows me all the hosts in that group.
How do I create the panels like (format not intended):
Total Linux Hosts: 27
Hosts: Host1, host2, host3… host27
I’m stumped! (and a newbie)
Thanks!!!
I’ve been working something similar for icinga/icinga web2. From what I understand now is that if you want to develop a plugin that will be truly usefull for the community you should develop a datasource plugin retrieving data from zabbix (this is still not time series data - I’m not sure if data source makes sense,). However, if you’re selifsh as I am you can:
- Add CORS support in front of zabbix
- Write you’re own javascript code making appropriate REST calls and rendering in grafana HTML panel or your own panel plugin. Check links below - it’s what I did for for grafana and icinga2, but will work quite similar for zabbix.
https://funinit.wordpress.com/2017/12/07/icinga-web2-and-grafana-working-together/
https://github.com/cinek810/icingaweb2-panel
Try to use SQL (if you have MySQL/MariaDB/Postrges as Zabbix backend). See examples here
http://play.grafana-zabbix.org/dashboard/db/zabbix-db-mysql?orgId=2
Thank you! That was just the kick in the pants and example I needed. I am off an running!
