Seems any plug-ins doesn’t show the disconnected hosts (using Zabbix Agent and disabled the Agent service) even when the ‘Show Disabled Item’ is on.
When I tried to select hosts in the configuration view, I can the disconnected host, but since it is disconnected, there is no value, is this the reason I cannot see them in graphs?
I would like to see N/A or No Data, but the host name should be seen.
It is new installation with latest Zabbix and Grafana versions using Grafana Zabbix plugins (alexanderzobnin-zabbix-app). The server is CentOS 7 and the Agent is installed in a Window server with passive mode.
Tried to Google but no clue at all. Appreciate if you have any suggestion.
