I’m looking for a way to import or build a chart for Microsoft’s insights for the Yammer application. Is it possible ?
Thanks in advance,
Regards,
Thanks in advance,
Regards,
Hi, @duffo!
You can build a Grafana dashboard using metrics from Application Insights with Azure Monitor data source plugin: https://grafana.com/grafana/plugins/grafana-azure-monitor-datasource
Best regards,
Lukas
Hi, @duffo!
if you don’t have your metrics set up in Application Insights, then I don’t think it’s going to be possible to visualize Yammer-related metrics directly from Grafana. I didn’t see any plugin that integrates directly with Yammer, but the set up of Yammer with Application Insights is pretty straightforward and then you can use it with Grafana by Azure Monitor data source plugin.
Best regards,
Lukas
