1- Aim - To create a Grafana Dashboard.
2- I have added Azure Monitor Data source.
3- I want to create a Grafana Dashboard which can show the standard metrics from Azure Monitor for all Azure VMs.
4- Don’t want to enable LogAnalytics or VMInsight on Azure Portal due to cost constraints.
5- Just want to show standard metrics for example - Percentage CPU for All VMs for All resource groups on a single panel.
6- On Azure portal, on monitor, it having restriction, we cannot show the metrics for all RG and for all VMs on a single panel. Need to do customization on Grafana side.
7 Using Grafana 9.0 version.
Sounds like this webinar may be helpful for your tasks:
Visualizing Microsoft Azure with Grafana
Tuesday, February 28th at 9:30 AM PST / 12:30 PM EST / 17:30 UTC
Learn how you can easily visualize and monitor your Microsoft Azure workloads in Grafana.
Thanks for providing these details. I have already imported these Grafana dashboards but its does not serve my purpose. I need to customize it.
1- I want to pull standard metrics from Azure monitor.
2- On Grafana dashboard, it should show the data like this -
Multiple RG → All VMs under multiple RGs → Percentage CPU for all VMs
The dashboards available on Grafana site does not suffice this purpose. Thats why I am seeking for help. Restriction is that I don’t want to enable analytics, insights etc on Azure because I am having budget constraints. If I can enable analytics or insights etc then I know that I can pull multiple data at single place using queries.
Kindly help…
Apart from it can someone help to anaswer below questions also:
1- Can Alerts under Azure monitor be integrated on Grafana?
2- If yes then how?
I have asked multiple queries in a single thread but I am stuck and I need help on urgent basis.
