Grafana 10
I am trying to create a Grafana dashboard to monitor Azure VMs as an admin to visualize data.
I have used the following template dashboards and resources to set it up:
- Medium Article on Monitoring Azure VMs Using Grafana
- [Azure Virtual Machine Dashboard (10532-azure-virtual-machine/)
- Azure Insights Virtual Machines by Resource Group Dashboard
What happened?
One of the dashboards, “azure-insights-virtual-machines-by-resource-group,” doesn’t work. Additionally, when I try to use the “0532-azure-virtual-machine” dashboard and combine more than one VM in a view, it doesn’t work either.
I expected the dashboards to display the monitoring data for multiple Azure VMs correctly.
Yes, I received the following errors:
Log analytics link forbidden
Could someone guide me on how the query should be done for these dashboards or provide a solution for monitoring multiple Azure VMs in a single view?
Thank you
