Y axis not converting bytes to TB properly
Hi everyone
New to Grafana but I did Google a bit around my issue but came up empty.
So I’m playing around trying to learn telegraf+influxdb+grafana and as a start I enabled SNMP on my QNAP NAS to pull some metrics from it.
I’m struggling a bit with understanding how Grafana converts from bytes to TB.
Ok, first off, here’s a sample of the data I have:
https://puu.sh/B1epc/d58e53f436.png
The MIB file defines the object sysVolumeFreeSizeEX as follows:
sysVolumeFreeSizeEX OBJECT-TYPE
SYNTAX Counter64
ACCESS read-only
STATUS mandatory
DESCRIPTION “System Volume free size in byte.
::= { sysVolumeEntryEx 5 }
Ok, so as an aside, the MIB file seems wrong because the values actually look like they’re in kilobytes. In any case, when I bring the data into Grafana, I just multiply them by 1024.
So in Excel, I just did a crude calculation to go from bytes to KB to MB to GB and then finally to TB (dividing by 1024 each time).
Here’s what that looks like:
https://puu.sh/B1eCW/82fc983757.png
And if I log in to my NAS, this is what it shows me for free space:
https : // puu . sh / B1eHz / efd9b3aede.png
So my calcs match what the NAS is saying.
But here is the Grafana number for GB:
https : // puu . sh / B1eKj / 15b3d0b334.png
Here’s the data source setup where I bring the metric into Grafana:
https : // puu . sh / B1eLN / 5c668e2b61 . png
And here is where I choose the unit for the axis:
https : // puu . sh / B1eQQ / f68aa7ae76.png
I cannot understand how Grafana gets 1.3873564TB.
Apologies for messing up the links but new users can only post 2 links max.
You should select the unit in Grafana which reflects the resolution of the data returned not what you want to visualize - Grafana will automatically adjust to TB for example. So you shouldn’t need to multiply with 1024.
